Westin HDX Drop Steps
pkrider
6.7 diesel
Dang those look great! Wish I would of taken my time and searched on this thread before I got my NFab ones...[emoji856]
Tmemz
how do you like them? I am undecided between these and the ici magnum rt ones
Sent from my SAMSUNG-SM-G920A using Tapatalk
joeygster
Ancaster, Ontario
I like the flow of the Westins better & the oversized steps for driver & front seat passenger.
Some people with the ICI Magnum RT's were also complaining about rust after one winter...so that got me worried since I'm in Ontario & we use a ton of rock salt & brine on the roads during winter.
I'm now almost through one winter with the Westins & they are rust free.
huntergreen
Marine Corps Navy Badge
Looks great!
adubree86
adubree86
Indianapolis, IN
2017 Ram 2500
Love em. I've heard of the ICIs rusting quickly. Also I've stood on a set and the flex pretty bad. The Westins are stout.
benjamin247
6.4L Hemi
Finally got those annoying rivnuts in! I was at that point where I brought it to a shop to have the rivnuts installed, but they didn't have the tool to do it. I used the method found on youtube where you use another nut to have the rivnut expand. I found installing the bracket and putting the rivnut in the hole where it is suppose to be installed, and then expanding the rivnut was MUCH easier. The rivnuts I bought from amazon (link in previous post) worked out just fine. Here is a pic of mine installed:
picture.php
joeygster
Ancaster, Ontario
Hey Boys, for anyone with the Westin HDX Drop Steps...have a look at the mounting screws/nuts for the actual step plate. There are three per step.
Mine got some rust over the winter despite me rust spraying them.
I contacted Westin & after sending them a picture of the rusting screw they sent me a new hardware kit.
This time the screws/nuts are stainless steel. The install instructions mention that the existing hardware was prone to rusting.
Tom88
They must be aware of this problem because my steps came with a bag of stainless screws and a note saying these were replacements for the ones on the steps as they were prone to rusting.
joeygster
Ancaster, Ontario
That's good that they're being proactive.
gustheram
Central Florida
5.7L
Good info! Thanks. I'll keep an eye on mine. No winter salt down here but we have the beach lol.
On another note, keep an eye on the 2 screws that go through the rocker panel on the front driver side. I had been noticing a little flex in my steps, which I didn't have at the beginning. The other day I crawled under and checked everything out and found out the nuts for those 2 screws had almost completely backed off. Added some blue loctite and torqued them back down. No more flex, but not good that they almost came off.
joeygster
Ancaster, Ontario
Will have to check those bolts on mine. Thanks
bankshot
Hemi5.7
I mounted westin 7 inch boards on a 2017 ram. I tried both methods of installing the rivet nuts. The supplied nuts when used as the instructions laid out are a pita and the nut twisted after the nut started to compress. Using one of the methods found on utube, the factory rivets worked. Use an 8mm X1.25x40 bolt, a washer with the teeth(can't remember the name) a smooth washer and a jam nut. Insert the nut screwed on the 8x1.25 with a jam nut. Hold the bolt and turn the jam nut. The jam nut will collapse the rivet without turning it. It takes a couple of minutes with no problems. Very easy. Photos when I can take them.
No members online now.
