What engine air filter are you running?
JS1500
AR
For those of you that are running a conventional engine air intake setup, what engine air filter are you using? I currently have the stock reusable one on mine, but I'm looking into changing it out if there are better aftermarket options out there.
U&A
2016 3500 SRW
6.4 HEMI
OEM. I tried wix one time and it was not as good of quality in my opinion. The foam on the wix was not as nice and did not seem as if it would create as good of a sale. The glue that holds the pleats from collapsing on the OEM was stronger and there was more of it compared to the wix.
Also the filter media on the OEM seems more plush and the wix seemed more like hard cardboard.
There used to be an excellent test on air filters from a member on BITOG. That page is no longer available for some reason. It gives you a 404 error and you cannot find it anymore. Basically his conclusion was very obvious showing that the high-performance air filters may have had a much better flow but the filtration ability wasn’t much worse.
If you planned on using the OEM air box it’s hard to be OEM filters.
This is JMO
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I am running a OEM filter as well.
Would look at something else if I ever do any mods to the motor such as a tune and headers.
turkeybird56
Central Texas
Have a AEM dry flo coming, will go to that from stock. Other than that, not really looking as truck spends more time parked than running...
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
In my oem air box I used oem, then wix, then aem dry.
Will always use aem drop in
homeguy
Calgary AB
2013 Big Horn
I’ve got a S&B in mine. Happy with it
misfit77
Forgot to mention, added cold air tube to bottom of stock box
U&A
2016 3500 SRW
6.4 HEMI
Where is the tube pulling air from, the engine compartment?
misfit77
Right behind bumper, behind flappy fender well.
Sorry about the dirt.74071c2db5d2d0b1ecb557ef4eba177c.jpg9646aa2862738cdfb471c8492c7c5305.jpg
Ramm5.7
So Cal
Same as above, ziptied to bumper bracket... add screen to keep out whatever might get sucked up or crawl up tube
misfit77
Love it!
Cheap and effective mod.
I used a bunch of left over parts from. My Jeep and vw days.
U&A
2016 3500 SRW
6.4 HEMI
AWSOME Guys!
Like the DIY Power mods that actually work. And a cheap too
