17x9 will clear your brakes just fine but that offset might give you troubles as 17x9 with +20mm offset is a little more shallow compared to the stock 20" wheels.
To give you an example the Rebel wheels are 17x8 +18, so that's 5.25" backspace, the factory 20's are 20x9 with a 19.5mm offset if i rememeber, so that's about 5.75" backspace. 17x9 +20 will be shallower than 5.75"
If you don't want the wheels to poke out, a 17x9 +6 will mimic the factory Rebel backspace (5.25"), and you'll be able to run 33's with those all day. Stock Rebel tire size is 285/70/17 but you should be able to run 305/70/17 as well. I went 17x9 -12mm offset which sits a little farther from the frame with 315/70/17 tires but i've also ran 37x12.5x17 with those wheels. I don't like my wheels tucked in like the factory and the -12mm offset offset have other benefits like been able to run tire chains if i wanted without having to worry about the chains knocking down my brake hoses, clear aftermarket ucas etc etc.
Have fun.
