Wheel and tire size help....
couleeman23
Magrath
13/14 Ram 1500's
Ok, so I ordered some rancho quick lifts for fiancé's truck to level it out. Now the search is on for wheels. This is where I am lost. I understand a bit, but get lost when I compare different sizes of wheels.
Long and short of it, what offset should I be looking at for rim sizes.
I am leaning towards a 325/70 or 325/65 (34-35")and have looked at the following wheels
17x9 20mm offset
17x8.5 12mm offset
18x9 12mm offset
Can anyone give me some insite as to what wheel and tire sizes I should realistically be looking at.
quietpeen
2021 TRX
Hellcat
Definitely not the 20mm offset.
BlownGP
Houston/Baton Rouge
Ok. Now is 20mm what is stock on the rams then??
+19 is stock, but yes +20 is pretty much stock.
I dont see a problem running that unless you have some huge tires or you just want to push them out farther with a lower offset.
couleeman23
couleeman23
Magrath
13/14 Ram 1500's
I'm looking at tires quite a bit bigger than what's on there now.
