Wheel bore
skirider
Looking for new wheels. Whats the deal on the hub bore. Do i have to match oem. Or do i order rings or something
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You either want to match OEM or make sure you get hub rings to make the aftermarket wheels hub centric. Your stock hub is 77.8mm and most wheels for that will have 78.1mm bore. A lot of aftermarket wheels have a 108mm or 110mm hub bore and therefore will require hub rings.
S
skirider
Ok hoa much those run. Man this rim thing aint cheap
brandonjansen
I would talk to whoever you're ordering your wheels from first. Some suppliers will include the hub rings with them. Otherwise I'd take a look at Motorsport Tech's website as you can get them from there as well.
Jantelaw
