Wheels Offset
marioman
Edmond OK
Does wheel offset matter when replacing wheels?
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
It will make a difference in how far a wheel either sticks out of the wheel well or how far sucked under the wheel well it is.
The more positive the offset the further under the wheel well.
The more negative the offset the further it will be towards the outside of the wheel well.
marioman
marioman
Edmond OK
How do I determine the lug position? We have a five lug array. But don't know what or how the measurements are determined
hemipwrd
Rowlett, TX
Here’s -18 offset on a 20x10 for reference, if it helps any.
Ramitiner
U.S. ARMY VETERAN
NJ
Hmm. Looking at some wheels that are 35 offset... How thick a spacer would I need to bring them back out and would it be safe?
Maligator
Hem 5.7
+35mm? You'd need roughly a 3/4" spacer just to get them back out to the stock +18mm. Like stated above, I'd look elsewhere
R.L.K.
Bristol , Tn.
I'd stick with a -24 mm max on a wheel offset , but to each other own . You could run a 2" spacer but I'd get a diff wheel .
The more negative offset the higher the load on wheel bearings and such .
A ( 0 ) offset will put your tires about 7/8" outside the fender , so figure from there as a + or - in millimeters.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Most of the wheels that are being run on here and that I've been looking at run from +1, 0, -1, -12, -18, -24, -44
I'm currently looking at some Fuel "Beast" (D654) 18x9 with a -12 offset
Ramitiner
U.S. ARMY VETERAN
NJ
So I'm getting 3/4"-2"... Which one is correct?
Ramitiner
U.S. ARMY VETERAN
NJ
Our wheels are 18 offset? Though it was 12???
yortnodnarb
Adrian,MI
Stock is +19mm (+.748"), so if you ran a +35mm (+1.378") you would need 5/8" of spacer just to get back to the stock backspacing. After that point any additional thickness of spacer will start pushing the tire assembly outside the factory setup. Chances are you'd have to run a spacer just to bolt the fronts on cause chances are the tires would hit the UCA with that much + offset.
Ramitiner
U.S. ARMY VETERAN
NJ
So not even an inch? That shouldn't be so bad
Ramitiner
U.S. ARMY VETERAN
NJ
Thank you btw. 5/8 really shouldn't hurt the bearings all that much, right,?
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Marioman if you haven't done it already, check out customwheeloffset.com. There are a bunch of pics of trucks and they tell you what wheel, wheel and tire size, offset of the wheels, etc. It may give you some more ideas. Good luck!
craigsez
Novascotia,Canada
Keep in mind,the higher the negative # the better the stability will get to a point BUT also remember its gonna put more strain on bearings and im sure there will be some amount of axle flex,how much I couldn't say....
Its the same deal on 18 wheelers when they go from duel wheels to super singles..
joshhhh
