Where to set fans to come on at after doing efan conversion?
newls1
GA
Hey guys, looking for a general consensus on what the appropriate temp should be where I set the efan to come on at after doing the efan conversion and 180f tstat swap... Currently i have it set to 201f turn on with ac on and 201 with ac off.. Really about how detailed I can get using the diablo i3 tuner. What are y'alls recommendation I should set the fan to turn on at? Lower then 200f to meet the 180 tstat? Just a little confused on what the best setting would be. Thanks for any input.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
All tuners I have talked to say 10-12 degrees over thermostat on all fan settings.
joshuaeb09
Medina County, TX
That sounds about right. If I remember correctly the Ram is set at 192 since the fan can only be run at a single speed while my Challenger has some lower temps for the lower speed modes in its tune.
N
newls1
GA
so im about good then at 200ish
joshuaeb09
Medina County, TX
Not getting the most out a 180, but your fan should stay off quite a bit of the time. If you're only running the canned tune, sounds like it, I'd say you're absolutely fine since that's accounting for the stock t-stat. Custom tune with a 180 is probably going to be pushing a little more timing and want the lower ECT, but that would be accounted for in the custom tune.
N
newls1
GA
how can i get the hemi fever tuning on my diablo i3? id like to try it out...
N
newls1
GA
i dont do fb.... any other way?
