Whining/howling noise while vehicle is in motion
NCRamowner92
Youngsville NC
2009 Ram 1500 SLT 2wd with Hemi 5.7 and 5 speed automatic. Whining and kind of howling begins around 25 mph and gets louder and more pronounced as speed increases. Shifting into neutral or switching engine off doesn't change sound. No abnormal noise when stopped.
Any ideas or insight would be greatly appreciated. Thank you.
shmedley
Downers Grove IL
Did you happen to replace the antenna or put some window vent visors on the truck?
NCRamowner92
NCRamowner92
Youngsville NC
No. Wasn't sure if this could be transmission or drivetrain related. Maybe a wheel end issue?
Rav3ncroft
Indiana
2018 RCSB Sport
I had a similar sound once on my 2004 and it ended up being u-joints.
caulk04
Supporting Vendor
Does the sound change pitch/tone if you sway left/right? Dead ringer for a wheel bearing.
caulk04
Supporting Vendor
I'd start by eyeballing the differential(s) then. Leaks at seals can give possible clues to bearing issues, check fluid levels and quality.
My 2009 started howling & it turned out that the Pinion Nut had backed off & that allows fluid to seep out right at the rear of the drive shaft
As that nut backs off the Pinion Gear shifts just enough to come into contact with the Ring Gear at the wrong angle. That causes a noise similar to twisting a metal pipe within another metal pipe
This happened a lot with the 2009 Ram 1500s
Chrysler came out with a fix for it, the fix was free, if it had not fixed by the dealership
They did the fix on my 2009, but they did it incorrectly & on a couple of drives from San Diego to Yuma & back.
The rear differential lost almost all of the fluid & they had to replace most of the inside of the differential
Good Luck
NCRamowner92
NCRamowner92
Youngsville NC
I put the rear axle on jackstands and we ran it up to about 30-35 mph for a few minutes. Noise came in about 25 or so. Before we shut it down, both rear wheels began to smoke and the smell was that of brakes getting too hot. Thoughts? Thank you.
NJMOPAR
Older and faster
ELizabeth, NJ
If there's smoke there's friction heating an ignition source like fluid or pad/shoe materials. Might want to pull the rear brakes and check everything including emergency brakes. Look at the piston seals, hose connections, axle seals slinging fluid, etc.
sublime2300
