Wider tire
ToddA2016
Boston
I have a ‘25 Ram Rebel with stock 275/70R18 and I want to go a little wider without needing spacers, wheels, level etc. I want everything to remain as is except a wider tire. Can I go with 295/70R18?
rzr6-4
nebraska
'09 2500
T
ToddA2016
Boston
Thanks. Those are the exact tires I was looking at at. 285 still gets the look I want
RamDiver
Marlborough, Ontario Canada
2021 DS
The 285s are pretty close in circumference to the OE size; you can decide to tweak the BCM for a more accurate speedo or not. The maximum circumference difference permitted in most states and provinces is 4%.
olyelr
Kewadin MI
A 295/70r18 is just over an inch taller than a 275/70r18.
A 305/65r18 is not quite a half inch taller.
Yogi51700
