Will these fit stock ‘19 PW without rubbing?
Scotts26
It’s my understanding through the wealth of knowledge I’ve gained from this forum that 35’s will fit no problem. Here’s a video that’s very informative.
Bruinjay
Bruinjay
SoCal
Great video! Is it a fact though that some 35’s rub while others don’t? If so, what exact tires are you guys running rub-free on suspension components or plastic?
Sando
Spring, TX
Hemi 6.4L
I ran 35x12.50 Toyo MT's for 2 years. First on stock wheels, then on AEV Katlas. I never experienced any rub at all. Now that I have moved to the 37" version of that tire, I had to trim and rub at full lock.
donivan
Houston
Specs on the 35" Toyos are almost identical to what was posted above for the G003's:
34.8" and 13.2". Based on Sando's input looks like you should be good to go.
SeaSickSailor
Hillsboro, Or
6.4L Hemi
All my research and past experience indicates that 35s will fit with no problem whatsoever. 37s requires some trim of splash guard and will give some rub at full lock. I keep going back and forth on what to get for Natasha (my ‘19 PW): 35s or 37s. I love the look and improved functionality of the 37s off-road. Down side is the extra mass and that I would only be able to carry one spare. 35s will let me carry two spares, which I have learned the hard way is the preferred MO when out wheeling. I have a nice spare tire shelf above my tonneau cover built by Nuthouse Industries. And a 35 will fit snugly into the spare tire puka under the bed (I may have to deflate and put a ratchet strap around it though). All that being said, it looks like I’m talking myself into 35s .
Rated R
USA
Do yourself a favor and fit some wider wheels while you're at it.
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Was planning on some 17x8.5” with +25 offset so that if I eventually decide to go to 37s they would work well for those as well. Thanks for confirming my intentions.
olyelr
Kewadin MI
AEV wheels I take it? That is a perfect size and offset for our trucks...but there are not many out there!
MoPowered
Retired
Orange County New York
2012 PW with Patagonia Milestar 37x12.25x17 on a 9” wide wide Pro comp wheel at 4 3/4 backspace and -6 offset trimmed pinch weld and plastic liner, lower front radius control arms no rub anywhere.
