Will these wheels work????
Silent425
Hey guys I have a 2013 Ram 1500 Laramie with 6" lift and 20x9 -12 offset Fuel Trophy wheels with 35x12.50 R20LT Nittos! Currently I have no rubbing anywhere, not even close!..I am looking into getting different wheels with a little more offset and was wondering if a 20x10 -24 offset would work on my truck with NO rubbing? ...Does anyone have this same setup if so pics would be awesome! Thanks in Advance!
quietpeen
2021 TRX
Hellcat
yes they should work with 35" tires
S
Silent425
You think they wont rub at all?....My current setup is not even close to rubbing, but its just a -12 offset, how much difference will there be with a -24 offset!?!?...I dont have much experience with offset wheels
quietpeen
2021 TRX
Hellcat
They will stick out an inch further
quietpeen
2021 TRX
Hellcat
And yes they shouldn't rub. I'm sure there are people running that wheel tire combo on 4" lifts
MADDOG
Living in a Firepit
An additional 12mm offset, or in this case -12mm, will result in the tires and wheels moving out an additional 0.47244094" as long as the wheel width and backspacing is the same as what you have now.
S
Silent425
Awesome Thank you!!
It actually will change a little bit though, the BS is the same at 4.50 but I have to go 20x10 on the new wheels instead of 20x9 in order to get the (-24) ...So what does that work out to be??..
quietpeen
2021 TRX
Hellcat
Awesome Thank you!!
see post # 4 ;)
Dangulo
Mine rubbed just slightly. A little trimming on the lower valence fixed it right up
S
Silent425
The lower valence on the front bumper. The black air dam looking thing
yeah I mean what was your setup on your truck? how big of lift, tires, wheels, offset etc...
Dangulo
Maxtrac 7" lift
20x10 moto metal 970's -24mm offset
35x12.5 nitto terra grapplers
