wiring in 7pin plug and brake controller help
usmc0311
2005 ram 1500 daytona edition
Alright I have a 05 ram 1500 without a tow package. I'm getting ready wire in a 7 pin plug and a brake controller. Questions I have is can I just tap into the hot wire on the reverse light in the tail light assembley or is there a certain place I need to do it at? Also I need to know which wire is the stop lamp switch wire is under my dash. The aux power from the plug to truck is pretty much a direct hook up to battery with a fuse correct?
C.Carmichael
Check under your dash.. There may be a light blue connector, factory trailer brakes. :)
Steve58
