temporary no oil pressure bug
work truck ram
Struggled through full rebuild on 3.7 with defective parts and shop manual type Os but she runs great now,, Almost. After warm the oil PSI drops to 0 at idle randomly until I tap the gas. Not so much as a tick out of it with 15 minutes idling at "0" psi. From reading there is a known issue with the port feeding the sensor. Already replaced the sensor and pigtail. Aftermarket gauge shows a similar drop at warm idle but not 0.
I am trying to disable the check gauges light and hold the gauge in a good position. Assuming this is a switch with only ever seeing two values on the gauge, 0 and strait up. Have tried grounding the factory wire and open circuit. Both ways I have had it display full pressure on start up then 0 pressure next start up.
Do I need a resistor? Is there another possible port to tap into, doubt it. Oil filter spacer with ports for a cooler maybe?
EdGs
FL
What oil pressure sensor? Aftermarket?
Use OE sensors where possible.
Daw14
South Florida
Have you tried a gauge that the oil feeds directly, no sensor , mechanical.
On my 5.7 with less than 10,000 miles , I had the sensor fail .
When I replaced it, I added a mechanical gauge in my dash , I used A-N fittings and a brass tee .
Now I know my factory gauge is accurate,as it now matches what my mechanical spot on.
Always replace sensors with OEM. For the best chance at a successful repair. No matter what manufacturer it was. Things work best with original factory specified parts most always.
