Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Heater Power Circuit - Fusible Link
This is a discussion on Heater Power Circuit - Fusible Link within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
88 D100, small V-6, auto I have not power at the fuse panel for my AC/Heater blower (fan). Is there ...
Reply
Old 02-04-2017, 04:12 PM   #1 (permalink)
Ram Year: 1988 D100
Engine: 3.9L V6
Default Heater Power Circuit - Fusible Link
Is there a fusible link in the power path? If so, where is it located? And what is good replacement?
Sponsored Ad
Register to remove this ad.
ewbloom is offline   Reply With Quote
Old 02-04-2017, 04:24 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
are you testing for power at the fuse with the key in the run position? the fusible link for the heater circuit is on the drivers side fender. it should be the orange 1 connected to the pink wire.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 02-04-2017, 04:31 PM   #3 (permalink)
Ram Year: 1988 D100
Engine: 3.9L V6
Default
Yes, I am testing with the key turned on. I even double checked another slot to make sure I was testing correctly.
I appreciate your gentle reminder. I need them on occasion.
Thank you for the location. Now to warm up a bit (temp is dropping now) before I head out and start the hunt.
So, are these readily available for replacement should it be bad? If so, what power rating do I need?
Old 02-04-2017, 09:55 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i think most parts stores still carry them or can get them. according the the wiring diagrams they are suppose to be a 20 gauge fusible link. i think they are color coded by size but not 100% sure.
__________________
Old 02-05-2017, 01:47 PM   #5 (permalink)
Ram Year: 1988 D100
Engine: 3.9L V6
Default
Thank you. Still having a hard time locating it in the batch of wires.
Old 02-05-2017, 02:18 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the fusible link is between the spitter and crimps.
__________________
Old 02-05-2017, 02:40 PM   #7 (permalink)
Ram Year: 1988 D100
Engine: 3.9L V6
Default
THANK YOU!
That is the bad / broken wire that was repaired before. The break on the Red end where all the wires split is right at the rubber molding.
The other end is pink and the dark brown that looks like the same brown in the fuse panel for the fan.
So, what is the AMP rating of this fusible link? I would rather just install the equivalent fuse.
While on that subject......why use a fusible link in the wiring harness and a fuse at the panel?
Old 02-05-2017, 03:10 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i don't know what rating you would need. all the wiring diagram says is 20 gauge.
i think the fusible links are there to prevent major overload to the cab or something like that. normal fuses blow immediately if overload where the fusible links are slower to blow if overloaded. i think you could replace them with self resetting circuit breakers or 12v circuit breakers but likely not worth the extra cost. it is not like the fusible links go bad that often.
__________________
Old 02-05-2017, 03:18 PM   #9 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
When ever I get a used old Dodge truck the FIRST thing I do is replace all the fuse able links with fuse holders and fuses. I had a 1977 Ramcharger I did it first on that is now coming up on the change being 20 years ago and it is still working perfectly with no blown fuses or problems with the electrical involved with the change. So I did it to my 1991 Dodge four years ago, no problems anymore, and I'll do it to my new 1976 Plymouth Trail Duster I just got today when I get around to it.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Add a circuit Bob2013Ram1500 Audio & Electronics 0 04-01-2016 09:41 AM
IOD circuit question ststock23 Audio & Electronics 2 03-02-2016 04:17 PM
Steering wheel heater and Seat heater question with aftermarket HU cbs Audio & Electronics 4 12-07-2015 04:42 AM
Geno's Garage - Cummins Block Heater/Heater Cable *Special* Geno's Garage Geno's Garage 0 03-12-2015 03:22 PM
Fusible links Nwa-ram 5.9 Common Rail 0 09-19-2014 09:54 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
