Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
1985 Dodge Power Ram W150 steering
This is a discussion on 1985 Dodge Power Ram W150 steering within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
Gonna work that first thing this morning. That orange straw sticking out of where that pin should be is befuddling ...
Reply
Old 11-26-2016, 09:06 AM   #11 (permalink)
Brucecmc's Avatar
Ram Year: 1985 Power Ram W-150
Engine: 318 V8 5.2L
Default
Gonna work that first thing this morning. That orange straw sticking out of where that pin should be is befuddling me.
Sponsored Ad
Register to remove this ad.
Brucecmc is offline   Reply With Quote
Old 11-26-2016, 10:52 AM   #12 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Has anybody heard of a hard polymer pin that is hammered into the "bell" shaped part of the coupling that connects to the input spline of the steering box ?
Old 11-26-2016, 05:55 PM   #13 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
So I think I know shy that clamp was on that coupling now. It's because of the shitty design. That pot coupling is in place, but the "bracket" that's suppose to cinch down around the pot and holds the guts of this thing in is only connected with these little flanges around the edges of that ring (see pic). In order to hold them you have pound them down (easier said than done with only one pair of hands. And hopefully with 2 pair, those little flanges get mashed in enough to hold. Bad design. Bad bad design. And I don't know shit
Old 11-26-2016, 05:56 PM   #14 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default Pic of bad design
Pic
Old 11-26-2016, 06:04 PM   #15 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
My further rant about the design. The little pin that you hammer in the top of the pot coupling, I'm not REALLY sure what it does. I'm sure it's suppose to keep the little metal "blocks" that get installed on the pin that is driven through the steering from backing out, shaft but man oh man, really? I would almost think there should be 2 of them, top and bottom? I dunno. But I don't have much confidence that after wrestling this for several hours that it is going to hold up. I do however think I'll apply that clamp on the shaft as well as precautionary measure to the bracket flanges not holding.
Old 11-26-2016, 07:06 PM   #16 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
removing coupler and all from the steering box is suppose to make rebuilding the coupler easier especially if you have a vice. hopefully this pic will show. if not there is a whole DIY thread on those on RCC
Ramcharger steering repair
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-26-2016, 07:20 PM   #17 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Yes. I used that DIY. However, I didn't remove the coupling from the input shaft of steering box. Didn't want to have to try and replace the "worm" pin holding it on. And I just discovered my improvised fix with the clamp won't work because the clamp doesn't span the width of the bracket holding everything in. So I now need to figure out what I can use that WILL span that width. DOH!!!!
Old 11-26-2016, 07:38 PM   #18 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the only thing that holds the coupler to the input shaft is a roll pin. all you need 5/16" roll pin punch to knock it out. the rebuild kit even comes with a new one
__________________
Old 11-26-2016, 07:50 PM   #19 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Mine is slightly different (think it was rebuilt before). The pot coupling on mine does not have a roll pin that goes all the way through. Ther is an entry hole, but no hole on the opposite side. One of my previous posts, I mentioned an orange looking wire or straw. A buddy of mine postulates that it's a hard polymer pin that is wedged in there. Would need to heat it and melt that polymer. Sounded like a More arduous reinstall, so I opt' to leave the pot in place and just remove the guts and replace. Which is where I'm at. Just trying to figure out a good method to shore up that metal plate that holds it all in (beyond the little flanges)
Old 11-26-2016, 08:03 PM   #20 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
just pound pin and plastic piece all at once. since you still have that plastic piece it sounds like the steering couple probably wasn't removed when the last guy had it apart. it might be a bit hard to see it in this pic since it was after painting it but i got one on my truck too. the steering box was off a 89 with with 45k miles
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1985 Dodge Ram W150 won't start unless ignition on Brucecmc General Discussions 4 12-14-2016 09:44 PM
Horn doesn't work 1985 power ram W150 Brucecmc General Discussions 24 12-08-2016 12:34 PM
1985 W150 repairs. Am I getting ripped off? I_chew_big_red General Discussions 3 05-07-2016 07:24 PM
1985 W150 Power Ram Deamer Member Trucks 10 04-14-2014 07:58 PM
1985 w150 acts like it runs out of gas when passing jcp dodge Engine & Performance 4 02-20-2013 12:19 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
