Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Towing & Hauling
Towing & Hauling
Which hitch should I tow with?
This is a discussion on Which hitch should I tow with? within the Towing & Hauling forums, part of the 1st Gen : 1981 - 1993 category!
My hitch came stock on the bumper (like everyone else). Should I keep the hitch and use it attached to ...
Like Tree1Likes
  • 1 Post By Chewy
Reply
Old 09-13-2013, 12:31 PM   #1 (permalink)
Deblackmon3's Avatar
Ram Year: 1990
Engine: LA 318
Default Which hitch should I tow with?
My hitch came stock on the bumper (like everyone else). Should I keep the hitch and use it attached to the bumper or would it be less stress on my truck to have a third party hitch and bolt it directly to the frame? I was considering adding just a REESE towpower Class 4 hitch and removing the metal plate below where the license plate is that the stock hitch is hooked up to.
My dad grills and makes barbeque for football games, church, and for selling/personal use. We have a HUGE grill that he tows which weighs a ton (not exaggerating) and a trailer that we put cars on, but his '96 Explorer only has a v6 and has trouble towing so we're switching to the Dodge for pulling
______________________________
If anyone wants to see pics of the grill with or without meat on it, I will deliver :P Last time we weighed all the meat it can cook 130 pounds on it. It's a nice a** grill, gas and charcoal burning, dual layer racks, stainless steel, it's niceee.
Sponsored Ad
Register to remove this ad.
Deblackmon3 is offline   Reply With Quote
Old 09-13-2013, 12:58 PM   #2 (permalink)
Chewy's Avatar
Ram Year: 2013
Engine: V8
Default
If it literally only weighs one ton, then the bumper will suffice as long as it's rust free and strong. If you're pulling a loaded car trailer, I'd want a class three or four!
Cthulhu likes this.
Chewy is offline   Reply With Quote
Old 09-13-2013, 12:59 PM   #3 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i don't know about your 90 but the bumper on my 91 is rated for 5000 lbs and 500 lbs tongue weight according to the info stamp on the bumper. i would guess your bumper should have same tow capabilities. do you know how much the grill weighs?
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 09-13-2013, 01:07 PM   #4 (permalink)
Ram Year: 1990
Engine: LA 318
Default
Yeah, there's a huge amount of rust on the bed, so it's like not actually attached at the rear to the chassis, so I don't really trust the bumper that much on towing a car trailer.
It weighs about a ton from what I can tell, he used to tow it with a 91 Pathfinder and it stressed the hell out of that engine, which I think eventually led it to die on him.
I'll have to find the stamp on the bumper to see what it's rated at, but I don't think it can manage a car trailer. I've towed the grill before with no problem, my worry is the trailer if we put a car or two on it. The 90 Ram is rated at 9000 lbs, but I think that's with another hitch and not the bumper.
Old 09-13-2013, 01:49 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the stamps should be below the license plate. i missed the part about towing cars. you might be able to tow 1 car on trailer with the stock bumper but not 2 cars. you would need at least a class 4 hitch to tow 2 cars and even then the trailer better have it s own brakes because i would not rely on the truck brakes to stop that much weight. stock bumper is about equivalent to a class 3 hitch. also if you have the overdrive transmission you want to make sure to turn overdrive off when you are towing or you may damage your transmission.
__________________
Old 09-13-2013, 02:09 PM   #6 (permalink)
Ram Year: 1990
Engine: LA 318
Default
Yeah, I wouldn't try breaking with two cars on :P I need to have the hitch wires redone since I actually don't have a wire for lights or brakes, but I know a guy that's big on electrical work which I suck at right now.
I wish my transmission had overdrive so I could save on gas, but it doesn't. I'm thinking about installing one if I have any money leftover from all my originally planned upgrades/refurbishing. Honestly, with what I want to do with my engine I'll need to replace the tranny anyway with a 5 speed since the torque I'll get from the rebuild (planning on doing the Hotrod 400hp build) with absolutely shred the teeth on my gearbox, so putting on an overdrive won't hurt my restore time or my budget that much.
Old 09-13-2013, 02:24 PM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
if you do go for upgrading your engine you may want to stick a newer magnum multport fuel injected engine in your truck. best bang for your buck as far as gaining power goes. i know i wouldn't mind sticking one in my 81. just need find another truck to take the engine and trans out of.
i think the stock transmission might be able to put up with 400hp.
__________________
Old 09-13-2013, 02:39 PM   #8 (permalink)
Ram Year: 1990
Engine: LA 318
Default
I've heard this a lot, but I want to keep with the original engine block at least. It's just special to me, I wouldn't be able to part with it, just like the truck. I want it to be like a family heirloom.
You think? I should put money aside for a new tranny if it can't handle it just to be safe.
Also, I found this. ^
Old 09-13-2013, 05:56 PM   #9 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
in the end it is really up to you. i just don't know if you will get the 400hp out of the stock engine even if you start building it. i know with magnum engines you are starting at 230hp instead of 170hp. the engines are just designed a bit better. i know i like the 318 magnum in my 93 a lot to the point where if i found another one it would go into my 81 as soon as i could get it in. plus most magnum engines are usually bolted to a overdrive transmission. just have to search for a 92-95 truck or van.
if you can afford it it would be a good idea to put money aside for a new transmission it it can't handle the power.
__________________
Old 09-25-2013, 06:15 PM   #10 (permalink)
88rambigblock's Avatar
Ram Year: 1985, 1988, 2001
Engine: 1970 coded 440 big block
Default
it is easy to get 400+ hp and torque out of a 318. I would always use a reese hitch if given the opportunity. it spreads the load out better on your truck and you will notice that hauling a trailer will be significantly easier to handle (not just for weight distribution along the trucks frame, but also how the trailer turns and such).
88rambigblock is offline   Reply With Quote
Reply
Bookmarks
Tags
1st gen hitch, towing 1st gen, which hitch 1st gen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
What hitch to get? rwalk Towing & Hauling 2 03-31-2013 09:50 PM
Hitch removal MF2000 Exterior 10 02-08-2012 07:22 PM
hitch help badfish888 General Discussions 6 09-10-2011 12:51 PM
Tow Hitch? Silverbullet08 General Discussions 17 08-27-2010 06:24 AM
hide a hitch - who has one truckin151 Exterior 4 07-01-2010 04:57 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
