Just Differentials. AAM 11.5 and Yukon GM 9.25. Yukon 9.25 spacer and ring gear bolts.
5.13s are perfect for 14+ Hemi trucks with 37s.
Wish you were near South Texas. I'd love to give your truck a test drive. Looking to swap gears next month if I can swing it. 2 quotes so far. $2600 & $2900 with Nitro kit. I'm gonna request a re-quote from both shops with AAM & Yukon gears you posted above (
"Just Differentials. AAM 11.5 and Yukon GM 9.25. Yukon 9.25 spacer and ring gear bolts.") and see if it brings the price down any.
@reloaderguy , thanks for all your input in the multiple gear swap threads. You and others have been a wealth of knowledge. Maybe there should be a stickied thread for gear swaps. Only posts are from those that have done a gear swap. I think it would REALLY help those researching and looking into getting it done. It may keep the HD area a little less cluttered because it would reduce gear threads from popping up every few months.
If I get my gears done next month, I'll try to start a thread about my experience.
Something like:
Year:
Model / 4x4 or 2wd:
Trans:
Tire Size:
Front R&P Gear Ratio & Brand:
Rear R&P Gear Ratio & Brand:
Parts List with Part #s:
Approximate out the door cost:
Shop name, Location, recommend to others:
Special Note: (ex: Ring gear spacer required for front diff, part#
-or- new carrier required for front diff, etc)
Other performance mods: ex: intake, exhaust, programmer, etc
Observations / comments: ex: RPM at "x" speed, responsiveness, towing, gear whine or lack of, etc.
