- Nov 9, 2016
- 623
- 577
- Pittsburgh, PA
- 2016
- 6.7 Cummins
SOLD
This adapter harness will plug in between your HVAC module and current Conversion Harness to provide the necessary wiring to make ATC work in your truck. It will then run back across the same path as the conversion harness and ultimately end up behind your driver side knee kick panel where it will connect to the cabin temperature sensor. $55 shipped to the lower 48.
Additional details can be found at:
http://www.ramforum.com/f75/how_add_automatic_temperature_control_atc_manual_temperature_control_truck-103456/
