Express to Laramie Dash/Cabin Harness Swap
1500Teej
Georgia
That i can't help with,my regular cab 14 Sport has pretty well every available interior option you could get on a regular cab in 14,so i've never looked into adding any interior options to it.If it doesn't make it go faster i'm usually not to interested in adding it,lol.The only thing i've added are paddle shifters,and i have to give that credit to my buddy who built a few of them back in 2015,and he installed them for me
Gotcha.
Those paddle shifters are
How difficult was the install and programming?
Gotcha.
You need the 8 speed and it's clock spring,they won't work on an RFE equipped truck.
Hunt up Brandon-W ,as he was making the kit for them to
1500Teej
Georgia
Thanks to everyone that's been helping me along the way with my project. I wanted to ask. Since I have a 2013 Ram and they say the communication with that BCM make it difficult for the truck to accept changes. Should I upgrade to a 2016-2018 BCM? My truck accepts changes but some of them don’t work right and they intermittently jump back and forth between the new configuration and old on. Also if I should upgrade BCMs can I grab a used one from a local yard and reprogram it through alfaobd?
1500Teej
Georgia
Hey everyone.
Just stopping by to add some more details and progress. I went back by the salvage yard and picked up a bcm/rf hub/keyfob I installed everything in my truck as is with no flashing or nothing. I installed the in-cab keyfob antennas and my truck will crank up remotely and from pressing the button. The issue I'm having now is that the truck starts and runs for about 5 seconds then immediately shuts off. Upon trying to restart the truck, I get the messages keyfob no detected and the vehicle is not in park and nor can I get the push to start button to cycle out of run to off once I push the button. I have to disconnect the battery cable. BCM from a 2015 Laramie with all the bells and whistles for that year. I have a 2013 Express rcsb with the old 6 speed transmission. Could it be that the truck keeps shutting down because the different VINs it detect, BCM different from the chassis? I went this direction because I was told its 200 to flash the ecu to the bcm and even then I was told theres a chance it might not work. So if anyone out there knows how to fix this issue. I'm all ears. Thanks everyone for your help.
1500Teej
Georgia
Update.
I got the 8hp70 swapped in and I am sorting through the diagram that Russell from SGA posted here
I wired everything up following this diagram. When I try to start my truck it won’t start and my PRND lights are all illuminated yellow and the electronic shifter will illuminate P. Then intermittently my dash will show only P in the normal colors and bounce back between. When the push to start is in run without the truck running (it won’t crank) my rotary shifter shows P as well as my EVIC. I believe I either have my CAN C lines going to the wrong place. I wired them into the CAN C lines coming off the RF HUB. I think that’s the issue. Only other thing I can think of is I should wire the CAN C lines into the shifter instead of the RF HUB. But I don’t wanna start splicing electronics until I know where what goes and vice versa. Also the ignition pink/white wire, where does that wire into? Can someone whos down this guide me in the correct direction? Need my truck running before Monday morning.
1500Teej
Georgia
Update.
I got everything working thru alfa obd (rewrote vin & installed the proper 8 speed harness connector that goes through the firewall passenger side in conjunction with the engine bay harness)!!
Ftank
