So I have the Big Horn with the 32gal tank. I drove it till the needle was below E. The "range" left on the computer was 48miles. I filled up and managed to squeeze in 27.75 gallons. So in theory I should have had 4gal left in the tank and an average of 20mpg I should have had about 80mi left on the range meter. Does my fuel system seem off?
If it is it's not that bad and I can live with it. I very rarely let the range till empty fall below 100mi plus at $2.65 a gallon (89oct) it makes for an expensive fill. This was just an experiment to see what's up. Anyone else have similar experiances and is there a fix.
