It wouldn't have anything to do with low tire pressure.
Have you driven through the water? Specifically a puddle where your 4wd connector could have gotten wet?
The dealer? You should have a warranty.
Mine came on a few times when I would drive through a lot of water but then eventually turned off after I believe it dried out. No issues with the actual 4wd working. I don't see there being an issue as long as you stay in 2wd just to be safe.
You got some problems if you hit a puddle and the connector gets moisture inside, those are supposed to be water tight.
if my tire pressures are low will the 4x4 still work? i am getting a 4x4 service light and my truck wont go into 4x4.. i am currently stuck and need a quick answer
So any one know what I should do Trans picks up just under 2k for power delivery!!!!!!!!!!So today went to car wash, just got like 9" of snow the day before and the 4wd light is blinking even though I'm in 2wd weird cause the transmission is acting crazy unless I put the tow option on.
Sent from my SM-N920P using Tapatalk
Hi Am3gross,
If you decide to visit your local dealership I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
