Cut my coils!
Big Boi
S. Fla
Since Im more than leveled now, I think Id outta start a new thread. I cut my oem coils yesterday by a lil' less than half a coil. Up front I got about 1" drop. Out back I got close to 1.5." I didnt cut the rear though. I was givin a set of used oem coils by another member for shipping cost. He'd already cut them before I got them.
So after running a half tank through her, and pulling a trailer. She rides just as good as stock. No alignment issues, and NO BOUNCING. Im gonna ride with it for another week or so before cutting them again.
Also, I think ricers and s10's ride like crap because a. the coils may have been heated, instead of cut. b too much of the coil was cut. c. the vehicles dont weigh enough.
Our trucks are pretty damn heavy, and I think that helps smooth out the ride.
Here are some pics
Before
Rear leveled
Pumpkin held up by jack, jack stands on frame just before axle. Sway bar end links, bottom bolt on shocks, and top bolt on pan hard bar removed. Lower the jack slowly, and the coils will fall out.
Cutting coil with cutoff wheel. Takes 60 seconds to cut through coil.
Two hr rain delay to start the front
Rain over, night here.
With the floor jack under the lower control arm. Loosen the upper ball joint, tie rod end, and upper nut on sway bar end link. I left the nuts on by a couple threads, and used a pickling for and my BFH to separate them. After a couple whacks (busted loose after 5-10 whacks, surprisingly) the componets will drop, and you can slowly lower the jack. I removed the shock, and pushed down on the lower control arm to pull the spring out.
Cut coil compared to stock coil.
Empty trailer
quietpeen
2021 TRX
Hellcat
nice work. Good info with pics
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
looks good
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Looks good
Big Boi
Big Boi
S. Fla
Thx guys (and Gal)! Im going on a road trip this weekend, so Ill let ya know how the ride is. Also, Im hoping to cut the coils again, next weekend, If the weather holds up.
quietpeen
2021 TRX
Hellcat
really? how much more are you looking to cut?
Big Boi
Big Boi
S. Fla
I definitly want the rear a lil lower to match the front. Im going to lower the rear first, and see what I end up with. Going to order a tonneau for my BDay, and maybe the air lift bagz.
Big Boi
Big Boi
S. Fla
Here's a pic of the Belltech 2/4 kit compared to my cut coils.
Truck rode a lil stiffer than stock on the highway. Kinda sporty like. Back when Hotchkis released the performance drop kit for the 02-05's. A friend of mine had it installed on his '04 Hemi QC. on the highway it was waaay too stiff, and you felt EVERY bump.
My truck handles a lil better than stock, but rides a lil stiffer as well.
quietpeen
2021 TRX
Hellcat
very nice....and money saved for other mods
Big Boi
Big Boi
S. Fla
Round two!
Cutting the rear coils another 1/2 a coil!
Pics after she has a bath...
Big Boi
Big Boi
S. Fla
Cut rears compared to oem
Oem, 1.5 coils cut, 2 coils cut.
Stance
