Drop kit back to stock height
justin443
Houston, TX
2010 RAM 1500 Sport 2wd
does anyone have experience installing or re-installing stock suspension? i heard a lot about the front springs giving people trouble. any help on what to do to release some tension so i can get the stock springs back in?
quietpeen
2021 TRX
Hellcat
wait, you currently have a level kit installed and want to remove it?
justin443
justin443
Houston, TX
i currently have a belltech street performance 2/4 drop kit on it and i am removing it to put stock springs and shocks on
quietpeen
2021 TRX
Hellcat
ahh ok, i moved this to the lowered section, might get more answers there
justin443
justin443
Houston, TX
ok i wasn't quite sure which section to put it in haha. thanks
quietpeen
2021 TRX
Hellcat
no problem, and i agree on the coil compressors. Once the coil is compressed i would think you could take the shock out just like taking out the stock shock
10ramsport
Sherwood, AR
I went from stock to low, low back to stock, then stock back to low, then low back to stock, now I'm sitting with stock front an 2" low in the rear! Haven't had any issues other than one rear shock squeaking a little. As long as you know what you are doing, or have a shop that does in my case, you should be fine. :)
justin443
justin443
Houston, TX
the drop is just extremely un-useful. i have 37 acres of land in east texas and a boat that we take out almost every weekend, and it is a bumpy road.
blackout11
alpharetts GA
2011 R/T
its easy to do no compressor needed just have someone step on lower arm insert top with rubber ring on first push bottom in if it hand up a swift push with your foot will pop it back in, just did it this weekend
Goodie1990
