- Jul 17, 2012
- 9,421
- 4,703
- Conroe, TX
- 2014 Ram 1500
- Whipple Supercharged 422" Hemi
Looks awesome!!
did you cut the factory front springs to get to 5" drop? cut half 1/2 coil?
any reason why you went with the Illicit cut brackets vs the Inez?
Can you post up side shots to see how the rear wheel is centered in the wheel well?
I seen the FB videos of the Inex Drop and the rear wheel still looked pushed forward, but It may just be bad camera angles.
Truck looks great! I see both front and rear tires are ~30.5" tall, is there a clearance issue that keeps it from being able to run the 295/45 up front also? or just personal preference
How would you rate those crown coils? Stiffer than stock or softer? I know its hard to compare with so many other variables changed at the same time though
