Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lowered
Lowered
Issues with factory front end link removal
This is a discussion on Issues with factory front end link removal within the Lowered forums, part of the 4th Gen : 2009 - Present category!
Hello everyone, I'm currently in the process of replacing the Hellwig front sway bar, and I wanted to put new ...
Like Tree4Likes
Reply
Old 12-30-2016, 04:35 PM   #1 (permalink)
Ram Year: 2014 Ram R/T
Engine: 5.7L Hemi
Default Issues with factory front end link removal
Hello everyone,
I'm currently in the process of replacing the Hellwig front sway bar, and I wanted to put new F-150 end links on the front, however I am having a hard time removing the bottom bolt from the end link. I'm holding the top of the end link with a wrench and using a ratchet to remove the bolt, but the bolt turns with some resistance, but the bolt isn't moving. Is there something else keeping this bolt from coming out?
I appreciate the help!
Sponsored Ad
Register to remove this ad.
J3FF3RSON is offline   Reply With Quote
Old 12-30-2016, 04:41 PM   #2 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
I used vice grips on the upper portion of the stock end link, mine became sacrificial.
J3FF3RSON likes this.
__________________
2014 Charcoal RAM 1500 RCSB 5.7 8SPD 2WD
2016 White Suburban 1500 5.3 6SPD 2WD
A bunch of 73 Chevy C10 truck parts!
moregrip is offline   Reply With Quote
Old 12-30-2016, 05:00 PM   #3 (permalink)
Engine: 5.7L Hemi
Default
The top portion doesn't move at all when I'm spinning the nut at the bottom because my wrench is holding it firm just under the top threads. Should I be holding the end link at a different location?
Old 12-30-2016, 05:16 PM   #4 (permalink)
jettajam1's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
You will need to hold the lower hex when loosening the lower nut. I encountered the same thing and right before I took a sawzall to it....I noticed the lower hex. I used a ratcheting box end wrench for the nut and a 5/16? box for the hex.
Here they are removed (notice the lower hex)
And the Mevotechs I installed
__________________
2012 Bighorn CC 5.7 Hemi, Mufflex DOD24M, Moe's 5 inch tips, S&B CAI, BT catch can, Diablo i2 with Hemifever 89 tune, Mag-Hytech differential cover, AntennaX shorty, Line-X spray-in bedliner, Bakflip VP, Bedrug Mat, BT under hood engine kit (satin), EBC brakes, Bilstein 4600s, Hellwig swaybars, 87MM throttle body
jettajam1 is offline   Reply With Quote
Old 12-30-2016, 05:28 PM   #5 (permalink)
Engine: 5.7L Hemi
Default
That picture is actually very helpful! Alright, lets see if I can get these off before dark!
Thanks for the responses!
Old 12-30-2016, 05:34 PM   #6 (permalink)
jettajam1's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Keep us posted on the outcome
__________________
Old 12-30-2016, 07:26 PM   #7 (permalink)
Engine: 5.7L Hemi
Default
Quite possibly the most frustrating design I have ever seen in my life. My 3/4 12 point box wrench wouldn't hold the recessed bolt without slipping as i turned the 5/16 hex at the bottom, while no other size I had worked on it. My Flex Heads also wouldn't fit up there.
So they are still on the truck until I can source a tool that will work in that recessed hole, while simultaneously allowing another socket / wrench for the bottom hex bolt.
Old 12-30-2016, 07:36 PM   #8 (permalink)
jettajam1's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Frustrating is right....hence my sawzall comment. I was able to get a 19mm wrench in there at an angle and wedge it up against the frame just enough to hold the nut stationary, then started turning the hex (it was a bitch) but it worked.
Good luck brother,
__________________
Old 12-30-2016, 09:41 PM   #9 (permalink)
Engine: 5.7L Hemi
Default
Found a way to take that thing off. I went down to Sears and found a Max Access Rachet which allows the threaded part of the bottom to slide through the ratchet, keeping access to the bottom hex.
Tools I used for that bottom bolt:
- 1/4 Inch Drive Ratchet
- 6 inch 1/4 inch extension
- 5/16" Socket
-3/8 Inch Drive Max Access Rachet
- 3 Inch 3/8 inch Max Access Extension
- 18 Inch, Max Access Socket
See the pics below:
Old 12-30-2016, 09:49 PM   #10 (permalink)
grozier's Avatar
Ram Year: 2015
Engine: hemi 5.7
Default
You say put a F-150 part on a ram?
Sent from my SM-G935T using Tapatalk
grozier is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Step pad removal factory steps MindlessDeviant Exterior 1 05-14-2014 09:43 PM
Front emblem removal *tim* Exterior 4 04-30-2013 09:31 PM
factory alarm removal Black12 Audio & Electronics 12 12-10-2012 10:03 PM
Front Seat Removal BlackedOutHemi Interior 8 12-26-2011 01:03 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
