Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lifted
Sponsored Ads
Register to remove these ads.
Lifted
Level 4th Gen Questions
This is a discussion on Level 4th Gen Questions within the Lifted forums, part of the 4th Gen : 2009 - Present category!
I didn't want to hijack the other thread but this level thing has got me a little confused... First part ...
Reply
Old 07-27-2011, 08:00 PM   #1 (permalink)
joetama's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default Level 4th Gen Questions
First part of confusion... From reading the front needs to go up 2"-2.5" to be 'level'. Some kits are front 2" or 2.5" but some like the Rough Country are 2.5" Strut Spacers in the Front and 1.75" Coil Spacers in the rear and the one posted in the other thread which is 2.5" F 1.5" R... So what gives? The Rough Country one is only a .75" level? Or is it supposed to have a slight rake so its more of a ~2" lift kit and the word 'level' is misused?
Also, tires... I'm needing some direction. I want to put on some more aggressive All Terrain tires on the truck with the stock rims. Part for look and part for fun. 99% of the time it will be on dry/wet pavement but I want something that will dominate deep snow, light mud, dirt, etc. I was looking at the Pro Comp tires but heard they do awful and are unsafe on ice. (Ohio we get more ice than snow)
So what I'm looking at now is Cooper Zeon LTZ or Discover A/T3, Nitto Terra Grappler, BFG Rugged (All) Terrain T/A, Goodyear Wrangler Duratrac or AT/S or SilentArmor, or a few others. Any good, bad, or ugly on that list?
Also, I've noticed that most of the tires above are the "LT" type and only come in 275/65R20 or 285/60R20. Any issues with running these size tires? Right now the truck has 275/60R20.
Thanks a head of time for the help.
-Aaron
__________________
2011 Big Horn || 5.7 HEMI || AirRaid CAI || Borla Exhaust || BakFlip || BedRug
joetama is offline   Reply With Quote
Old 07-27-2011, 08:22 PM   #2 (permalink)
Musclemckeester's Avatar
Ram Year: 2010 Sport 4x4
Engine: 5.7L
Send a message via Yahoo to Musclemckeester
Default
On mine, I ran a 2" front spacer for about 3 months before my lift. It worked fine, truck still had a slight rake, but not anywhere near as bad as factory. 2.5" should get the front sitting level, but I wouldn't have wanted to add anything to the back, otherwise you'd keep the same rake you have now, or close to it.
Your best bet, forget the coil spacers to level your truck. Get the Bilstein 5100 adjustable front shocks. They have 4 settings you can put them at - most people set them at 2.8" which is the max setting. That will get the front up level, then if you need to you can always at a .75" spacer to the back if you feel it nessary. As things in the front settle though, it should sit pretty well even.
I'd recommend getting measurements now to see where you're at. On level ground, measure ground to the middle of the fender, front and rear. That will get you an idea how much you're off and what you need to get it sitting level.
As far as tires go, I can tell you the Terra Grapplers are nearly useless on wet roads so I really can't see them doing much for you on ice/snow. The BFG A/T are a pretty decent tire overall.
__________________
Interior: Color matched trim, complete LED swap | Exterior: AMP Research steps, Custom heads and fogs, 20" Fuel Hostages, 37" Mud Grapplers, tow mirrors, tow hooks | Performance: Yukon 4.56s, Vararam Intake, DiabloSport Trinity, Raceland USA e-cutout, BT Catch Can | Lift: 6" Pro Comp lift, 1.25" RCX body lift, Bilstein 5100s set at 2.8" | Plus more... My Pictures
Musclemckeester is offline   Reply With Quote
Old 07-27-2011, 08:33 PM   #3 (permalink)
0212353's Avatar
RF Admin / Vendor
Ram Year: 2010 1500 Crew
Engine: 5.7L
Send a message via AIM to 0212353 Send a message via MSN to 0212353 Send a message via Yahoo to 0212353
Default
I stuck with a 2 incher because I didn't want to have any issues with cv vibrations
__________________
RamForum.com Administrator / Preferred Vendor
RetroShop.us - Custom Automotive Lighting Specialists / Fukken Wax - the BEST waterless wash & wax on the planet!
0212353 is online now   Reply With Quote
Old 07-27-2011, 08:34 PM   #4 (permalink)
LB3711's Avatar
Ram Year: 2011
Engine: 5.7L Hemi
Send a message via AIM to LB3711 Send a message via Yahoo to LB3711
Default
I got 2" also. I hope next month I'll have mine on. I'll have pics. I got new tires in mind when Its time to change mine out.
__________________
2011 Dodge Ram 1500 QC Hemi Big Horn 4x4 -- Has Mods
LB3711 is online now   Reply With Quote
Old 07-27-2011, 08:36 PM   #5 (permalink)
BlackedOutHemi's Avatar
Super Moderator
Ram Year: 2012 & 2012
Engine: 5.7L HEMI & 6.7L Cummins
Default
I'm running the 305/55/R20 Cooper's, and so far love them. Haven't had anything to really "test" them on, but I've never heard anything bad about them. The goodyear duratracs have been said to be riding like on bricks.
__________________
RamForum.com Moderator
Black Truck Club #30 Texas Truck Club #1
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
BlackedOutHemi is online now   Reply With Quote
Old 07-27-2011, 09:37 PM   #6 (permalink)
quietpeen's Avatar
Administrator
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
Send a message via AIM to quietpeen Send a message via Yahoo to quietpeen
Default
I'm gonna go with a 2" hellbent spacer for the same reason as jeremy stated
quietpeen is offline   Reply With Quote
Old 07-27-2011, 09:50 PM   #7 (permalink)
Roman4405's Avatar
Ram Year: 2011 1500 SLT QC
Engine: 5.7 Hemi
Default
I had the Terra Grapplers on my last truck and was pretty happy with them. I didn't have to use them on ice but I had no problem on wet roads. I'm looking forward to seeing what your truck looks like after the level since that's what I think I'm gonna do. Thanks for starting this thread by the way, I had the same questions as you.
__________________
-Justin
BTC Member #40
Roman4405 is offline   Reply With Quote
Old 07-28-2011, 12:35 AM   #8 (permalink)
joetama's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
So lifting the front more than 2 inches without a 'real' lift kit can cause the dreaded vibration issue?
__________________
Old 07-28-2011, 08:01 AM   #9 (permalink)
quietpeen's Avatar
Administrator
Engine: Hemi 5.7
Default
on the 06-08's with 2.5" spacers - they seemed to be more prone to the "death wobble".........not sure about the 4th gens.
Old 07-28-2011, 08:15 AM   #10 (permalink)
0212353's Avatar
RF Admin / Vendor
Engine: 5.7L
Default
the front end is exactly the same as the 06-08s.
On "difference" - in mid 08 Dodge removed a 1/4" plate that sat on top of the strut. So, HBS sends that with their kits. Other companies........had no clue.
__________________
Reply
Bookmarks
Tags
coil spacers, leveling kit, strut spacers
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2007 2WD Level? DrewRam Lifted 26 04-03-2013 10:46 PM
06 2wd level kit? sportstud0903 Lifted 5 06-25-2011 09:47 PM
What's the proper way to level? Banned Lifted 7 04-28-2011 11:56 AM
hbs level kit 98sporttj Lifted 9 04-11-2011 09:10 PM
HBS 2" Level...35's? DeputyDipShizz Lifted 9 02-25-2011 04:21 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
