jknappen
Is it crucial to put the 5100s set at 2.8 in the front on a 2013 ram express 4x4 with a zone 6 inch lift? Would it be beneficial to replace all 4 shocks and struts or do the lift kits come with all of that stuff
No not crucial , depends on if you want to be level or not .Is it crucial to put the 5100s set at 2.8 in the front on a 2013 ram express 4x4 with a zone 6 inch lift? Would it be beneficial to replace all 4 shocks and struts or do the lift kits come with all of that stuff
Zone lift will come with rear nitro shocks or it has the option to upgrade to Fox shocks.
- from the ******* with nothing constructive to say
Arn't the Fox shocks adjustable too , just like the Bilsteins?
I thought I read somewhere FOX owns BDS & ZONE ?
Speedometer being off has nothing to do with wheel diameter , overall tire diameter is what determines that . Not sure on amounts , maybe Thatdude596 or brandonjansen or someone can chime in .also how bad off will speedometer be off with the 20s compared to the 22s and how can it be corrected?
Sounds good. How is fitment with 22 compared to 20 inch. and 37's what will be the best bet I'm thinking I would like the 22s and 37s however just not sure how much they wills tick out and again I will be running fender flares painted to match i like how they look. will 22 affect things a terrible amount
Bowling Greenjk honestly I don't know your finances and only yiu can make that choice.you can keep your factory rims and add a 1.5 spacer to get some stance. those and 35s would be cheaper all the way around . my theory is go big or go home..with that being said it sees about 25-75 miles a week and I'm ok with whatever breaks, and replacement tire costs, brakes, parts ,etc..
where at in Kentucky are you, I grew up in Greenup county
As others have already mentioned, the rim diameter itself doesn't mean anything fitment wise. It's the rim width/offset, and tire diameter/width that play into the calculation. Without knowing what rim width/offset and tire size you want to run I can't tell you anything about how far they'll stick out.
And again, as the others mentioned the overall tire size is what affects your speedometer, not the rim diameter. If can be corrected with an aftermarket tuner.
