hemipwrd
For those of you with the opt7 LED lights in your quad headlights, when installed where are the led's located? In mine they are roughly at the 2 and 8 position, I would assume they should more at 3 and 9. I double checked everything, just wanted to make sure that's correct or if there's a way to adjust them accordingly. Also, I have radio interference when the lights are on, I know some have the same issue while others are lucky enough not to get it, anyways I contacted the company and they are sending me new drivers. Once I get them in I'll update whether it worked or not.
