Opt7 with quad lights..
hemipwrd
Rowlett, TX
For those of you with the opt7 LED lights in your quad headlights, when installed where are the led's located? In mine they are roughly at the 2 and 8 position, I would assume they should more at 3 and 9. I double checked everything, just wanted to make sure that's correct or if there's a way to adjust them accordingly. Also, I have radio interference when the lights are on, I know some have the same issue while others are lucky enough not to get it, anyways I contacted the company and they are sending me new drivers. Once I get them in I'll update whether it worked or not.
OnSale
5th Gen Crew
Philadelphia, Pa
In my quads they were at 9 and 3. If you google "clocking opt7 led bulbs" you will find guides on how to drill a new hole on the seating ring to adjust them.
Once mine where set to 9 and 3 and i made sure the L side was left and tbe R side was right, there were amazing and had a nice clean projector "like" cut off. It wasnt as good as hids in a projector but for being in a halogen lense they were damn impressive.
Sent from my LGLS775 using Tapatalk
OnSale
5th Gen Crew
Philadelphia, Pa
This is what they should look like once clocked and positioned correctly in a set of oem quads.
These pics are from my 2012 Ram 1500 with oem black housing quads and Opt7 H11 FluxBeam-X Low Beams
hemipwrd
hemipwrd
Rowlett, TX
Ok, thanks. I'll have to look into that and pull them all apart.
