CostaRam
Hi!
I drove from Costa RIca to Panama to do some diving there and ripped the sidewall of my almost new Mickey Thompson Baja ATZ a tire on a rebar in a hole on a rural bridge.
I went and changed all tires as they are substantial cheaper in Panama as in Costa Rica and wanted to have the wheels aligned.
The drivers side wheel has a slight play rocking the wheel back and forth and this is usually a sign of a worn wheel bearing.
They refused to do the alignment as it is not accurate and said that i have to change the bearing.
I checked with the dealership and they sent me the exploded view showing the whole assembly (a round plate with the 5 wheel studs attached) for 450$.
As it seems the bearing is inside and they sell the whole assembly and not only the bearing.
Is there a way to get only the wheel bearing and use a press to pry it out and push a new bearing in (as in all other cars i had)?
Main problem is now that i have to drive back 400 miles and this play in the wheel bearing makes me a bit nervous ...
Thanks
Chris
Thanks
Chris
