Will wheels fit?
Fanta1500
Fanta1500
Albany NY
They do rub on driver side full lock, left and in reverse. Only slightly but not worried about it
quietpeen
2021 TRX
Hellcat
i'm honestly shocked that they do rub at all, but not all trucks are built equal.
oddly enough that is the only place i get slight rubbing with my setup and my bilsteins are at 2.1
Fanta1500
Fanta1500
Albany NY
Yeah I am shocked, mine are at 2.8... good thing I went with that setting instead of 2.1 or else it would be a nice rub lol
Budki
I have BFG KO2 35 x 12.5 tires on 20x10 rims with -24 offset. I had to trim even with 3" level up front. 59ccb7960d2f0c4c9135964fcb68e20f.jpge88a7aaf0413fec5ea8bbbc6c487819c.jpg
I had to trim back the inner seam metal behind the plastic inner fender. That allowed me to use a heat gun to reshape the plastic fender back some. I also used spacers between the metal fender lip and inner plastic fender to get another 1/2" of space near the bottom where it rubbed. I also had to remove the plastic stone guard.
cyberpine
Don't quote me but on a level I'm not sure you'd have any rub. I only run 33s. And I don't rub on my 20x10. I didn't even rub at stock height.
What offset? 2x4? Stock suspension? Any pics?
cyberpine
I run a 20x10 fuel wheel -18 off set with a 305-55-20 Mickey Thompson atz p3 tire. I've got from leveled only. No rubbing at all. They stick out at least 2 inch and throw mud up side of rig constantly:..but no rubbing lol
Think they would rub w/o the lift? How about on a 2x4?
