This has been posted before so sorry for the redundancy.
If you're planning to update your instrument cluster to one with EVIC or simply want uconnect phone buttons on your express steering wheel see below.
You do not need to remove the steering wheel.
Step 1 - Remove airbag (3 tabs) - Use a screw driver.
Step 2 - Remove plastic panel on the steering wheel (6 screws). 4 are phillips and 2 are torx T20. The button panel is attached with 3 T10 torx.
