led interior upgrade
stevens
2015 Dodge Ram sport 4x4 crew
anyone know of a good setup for leds for interior? i got a 2015 ram sport, crew.....the inside lights are just not bright enought...also it be nice to get some foot well lighting all around as well.
lonestar21
CA
2019 Ram 1500 Big Horn
Try the sylvania led bulbs. Great quality products
RamXpress14
2014 Express Crew 4x4
I have the Express model, so I only have the single domelight in the middle controlled by the dashboard wheel switch.
I am going to install a DVD player for my daughter that includes an additional light.
So has anyone successfully or heard of successfully moving that domelight?
I was thinking of cutting a hole in the headliner towards the front in between the sunvisors to still have that domelight as well.
Any thoughts???
Idaho Falls, ID
I am wanting to do my 2013 Sport as well. I read that they came stock with LED's and from what I can tell they did but one map light is really dim and the other is flickering.
I popped the covers off and they don't look like the typical bulbs I've seen so I am really confused on what to get.
OnSale
5th Gen Crew
Philadelphia, Pa
Any thoughts???
This X 1000000 .... all I have is the crappy dull dome light controlled by the dash wheel. I HATE that I can't just reach back and flick on a light. Super frustrating.
Sort of on topic, but while I was at Pepboys browsing the Truck Accessories section I noticed (either Recon or Pilot Automotive... i forget) that they sell a square led, almost the size of a pack of playing cards. I was wondering if I could fabricate something out of a piece of interior plastic from the junkyard and my Dremel and make some sort of interior dome light for the front of the truck.
I'm going to pick up the led from Pepboys. It was only $19.99 and with the websites 30% off I can get it for $14 and it's worth trying to make something out of it.
Sent from hell via TapATalk
RamXpress14
Let us know how it works out
Metalizer
Pearland
One of our vendors Enlight makes a great kit
Sent from my SAMSUNG-SM-G891A using Tapatalk
Jsimon34
Lutz, Fl
These are the bulbs I got about 6-8 months ago from a local shop that does mostly aftermarket lighting for vehicles.... definitely a TON brighter than the stock.(photo taken at 3am)all in all paid $18 for the 3..... including photos of what they look like..... the small is for the map lights....
Grunt4Murica
2016 Ram 1500
Do they ship?! I need these!
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Any thoughts???
I had this thought about a 8 months ago and was going to add the overhead console to give me the added two map lights. I never went through with the project because I didn't want to get into cutting the headliner and such. Instead of moving the come light, consider adding the overhead console. That would give you the two map lights for additional lighting and give you a clean stock look.
Adam
Ferro
I need help with LEDs
Hey guys I have a 2016 dodge ram sport. I am trying to replace my map lights with LEDs. How do you get these bulbs in. I pulled off Lens cap it seems to me like you have to pull the whole consul down. I can't believe you have to go through all this just to replace two bulbs.
Jsimon34
Lutz, Fl
I honestly just grabbed some needle nose pliers and carefully pulled them out.... wrapping a rubberband around it and pulling also works from what I've seen....
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
I went with pliers too, wrapped the ends in tape. I tried a rubber band first and just couldn't get it to bite. Pliers popped them right out.
00R/T
CT
From what I understand, the 2016 (and possibly 2015) have LEDs in the overhead console so they can't be replaced like the bulbs in the earlier ones.
As for methods for removing the bulbs - heat shrink tubing. Let the bulb cool down for a while and then slide over a piece of heat shrink that's just big enough to fit. Turn on the light and let it get hot. Turn it off and let it cool a bit and then just yank it out with the heat shrink. It will be gripping the bulb quite well.
Ferro
I'm starting to think my truck has LEDs in it already don't know for sure but I'm started to think it does.
Niederlander
Sanford FL USA
3.6 V6
There is a video on YouTube where a guy makes a lasso with a small tie wrap, pushes it over the bulb, tightens it around the bass and pulls it right out.
Goodie1990
