2013 5.7 misfire issues update
grss429
So, here's the what i found.. pulled driver side valve cover.. inspected rocker arms found #3 rocker arm to just move freely over the valve spring, turned motor and the rocker barely closes the valve..
So my question is how do i determine if it's a failed push rod or a lifter?
can i just pull the rocker arm assembly off the top of head and replace the push rods?
I'm working on a 5.7 hemi, with a misfire on cylinder 3 here..
truck has 85k
Heres the codes
p0303 misfire on 3
p0219A P219A - Bank 1 Air/Fuel Ratio Imbalance
Heres what i've done
Swapped coils/plugs/injectors to #1 no change in the code.
02 sensors seem to be switching, (graphed them with scanner)
I checked the injector seals all of them looked fine.
The truck will not really misfire on idle, when you put a heavy load on it, (punching it from say take off) it will misfire hardcore, and start to shudder
Now the truck seems to have a louder "tick" them the so called hemi tick, its more noticeable
JasonK94Z
Moore, OK
If the rocker arm is loose, it wouldn’t open the valve all the way.
Tach_tech
5.7L HEMI
If the rocker arm barely moved to open the valve, then it’s probably a collapsed lifter. The push rod is easy to check, just pull the rocker shaft assembly off and remove the push rod.
G
grss429
thats what i was wondering.. if i can just take the rocker arm assembly off to check pushrods..
is there a for sure way to check cam/lifter for damage without head removal?
here is a video of it
https://youtu.be/6dlHf3tD8bA
Tach_tech
5.7L HEMI
If the push rod is straight and the valvespring isn’t broken or sitting funny, the only things it can be is the lifter or the cam. Either way the heads have to come off.
G
grss429
If the rocker arm is straight and the valvespring isn’t broken or sitting funny, the only things it can be is the lifter or the cam. Either way the heads have to come off.
did you see the video I posted? valve spring isn't broken, the rocker arm has alot of side to side play
Tach_tech
5.7L HEMI
I saw the video, im on my phone so it’s a little hard to see. Does it have any vertical play?
G
grss429
I'll have to check tomorrow to be 100% sure, but i'm pretty sure it's all side to side play
Tach_tech
5.7L HEMI
Vertical play is more of an issue then side to side. There will always be a little side to side play especially if that valve is closed, the video you posted does look a little excessive though. If you rotate the engine over twice by hand you should be able to watch how much that valve opens and compare it to other cylinders. Once the valve begins to open there shouldn’t be side to side play of the rocker arm.
G
grss429
all of the other rockers are TIGHT, this one has excessive play side to side, if i remember correctly that video was when the valve "open"
so in other terms, where does that lead me as far what to do next? i'd hate to pull a head for a pushrod or something
Tach_tech
5.7L HEMI
Pull that rocker shaft off, inspect the rockers. Pull the push rod and roll it on a flat surface, you’ll be able to see if it’s bent. Double check the spring isn’t cracked or broken, sometimes it’s hard to see. If everything checks out. It’s the cam or lifter.
G
grss429
Can i just unbolt the rocker shaft assembly? and pull all the rockers/pushrods without pulling intake and getting them through the vally?
Kap1
Ex Ram 1500 2013 owner
2022 Tundra
3.5 vvti
2013 5.7 hemi another cylinder misfire
Hi all, looks like there's a couple of 2013 hemi with cylinder misfire showed up all at once on this board. My truck is at the dealership now getting serviced so I thought to open a thread to document this issue:
I also got P0302 on my 1500 2013 hemi 70k miles . Also had the air fuel ratio Imbalance code, which they claimed was caused by exhaust manifold leak, which they fixed. That P0302 code has been showing on and off for the past couple years. Now it got worse and code stays on. Luckily my powertrain warranty covers it and they gave me a rental.
Dealer says that it could be right side cylinder head, clearance issue, lifters not sealing correctly, camlobe failure or cylinter head.
My truck is currently waiting in line for their engine tech to get to it to start trying the actual repairs... 2 other trucks ahead of me, and it'll take 2 weeks for them to get to mine. Last month, my truck spend 3 weeks at dealership for manifold bolts. Now it's been 2 weeks, and probably will be 2-3 more weeks
I'll report back with details once they get to my truck..
Tach_tech
5.7L HEMI
The push rods don’t go through the valley on the hemi, they’ll come straight out after pulling the rocker assembly off.
Marshallrfoster
My 2012 is having the same issue. I have no compression in cylinder #3.
chris52010trx4
ontario
A motor I picked up cheap had a misfire on cylinder 6... rocker arm did the same thing and was slightly chipped... no broken valve spring and rods were all straight.... we pulled head the lifter was seized and cam had a nice grind into it
Also this wasn't an MDS motor it came out of a 2500 but ya that's probably what ur gunna be looking at 9c0947717c745f09df766bcd0c00cfb8.jpg57a3eb439791db1afd06fe4ffed70cf8.jpg
Sent from my SM-N910W8 using Tapatalk
chrism1367
I wish we could figure out what causes it, cheap parts, oil or what. I got 4 months left on warranty, and get a little worried sometimes
chris52010trx4
ontario
This motor also had 300k km on it...the engine I have in my truck is at 227k km n been solid.... but ya not sure what it is
Kap1
2022 Tundra
3.5 vvti
I've been reading a lot about this on this and the other ramz forum, and there are dozens of people posting with 2012-2013 rams having exactly same issues, which start around 70-80k+ and above. Probably more of rams will be start having issues once they reach high milage.
So far, the wild guess is that maybe these years had bad batch or lifters. I've always used RedLine for 70k miles and still had all sorts of issues with lifters etc, so even the best oil won't help if you have any these issues.
chris52010trx4
ontario
This motor that had the cam and lifter failure just so happened to be a 2012 but ya probably a bad batch or something
