Davidpia11
So this is a really annoying one. I had a p0308 originally from a failed lifter and cam. Replaced those and it ran fine for about 100 miles. Well the cam i got from o’reilleys failed from the dowel pin breaking causing bent valves on 1,3,5, and 8 and bending 7 of 8 exhaust push rods. Again replaced the bent valves and pushrods and now have a misfire at idle only on cylinder 2. I swapped coils and plugs with cylinder 4 and misfire stayed on 2. Replaced the injector and still the same. Compression test comes back to 185 psi where the rest are roughly 200 psi. Did a leak down test as well and it passed with flying colors. Then pulled the valve cover and valves and rocker arms all seem normal. I also did a fuel induction and still a misfire. Im at a loss here.
