How did you delete your system?
Removed them (4 bolts).
Followed Shawns video!
Took about 15 min.
I basically removed them to install my heavy-duty transmission cooler in the same spot.
I will say this if you do remove this system and you don't do the same procedure that Shawn Demonstrates your pretty much guaranteed check engine light.
Like I said above the only reason I removed my system was to have a constant flow of cool air going through my coolers.
One less thing to worry about! One less thing to malfunction and cause other problems.
I honestly had no idea how often these were open and shut. But I damn sure didn't want them shut while I was going down the highway or interstate. Just to gain an extra 1 mpg.
I'm glad I removed the grill or I would have never Noticed them!
