500rider86
- Mar 13, 2017
- 49
- 15
- 2011
- Hemi 5.7L
Thanks to this forum, after I bought my truck used I was able to diagnose the ticking sound I was hearing as an exhaust manifold leak. Luckily it came with a 90 day, 4500 mile warrenty through gwc that covers the power train and exhaust manifold.
I talked to the mechanic in person. He seemed very confident and knowledgeable and since I've spent about 20 hours researching this thing I knew a lot about it. They let me back in the back where he had just finished working on a Ram that another customer brought in that had the same problem. He showed me the crappy studs dodge uses and explained that the heating and cooling of the thin bolts, along with rust, over time causes them to break. Unfortunatly they use the same bolts to replace them with. I've seen videos of this repair before where people use extraction screws. He walked me through how they do the entire process at the dealership. He showed me a bolt that had snapped off inside and told me that if they can't get them out the pull the head and send it to get machined out. He said about 75% of the time though if they take a rotating tool (like a dremel) and cut a thin slot in the bolt they can back it out with a thick straight screwdriver and save the customer a bunch of money.
I know a lot of people have fixed this on here, just sharing my expierence with the mechanic.
