Bigdaddycodes
- Jan 27, 2014
- 379
- 62
- Swift Current Saskatchewan
- 2013
- Hemi 5.7
Hey guys,
So I did a quick search and couldnt find a whole lot of information on this matter so I figured I would just make a new post. I am looking to be upgrading my whole fuel system over the winter here, Just trying to figure out how crazy to go and what all I am going to need, I am basically at the limits of my stock fuel system and larger injectors. So as of now the fuel system is stock except for the (i believe) 35lb injectors that came with the blower and the fuel rails that also come with. I have a set of aeromotive billet rails sitting here and going to be going to something like a 80lb injector, havent quite decided there. I am going to run a return style system and so I know Ill need a good fuel regulator, any recommendations? Definetly something with a boost refereance port. And then for lines im thinking -6 would be good enough or should I go up to a -8 and know im good. As for fuel pumps and filters, should I find a larger intank pump or should I do an inline pump and filter and are there any recommendations? I dont need anything e85 compatible as im in canada. What else am I missing here..
Anyways for the truck its going on will be my 13 sport, currently running just under 12 psi of boost and a fairly aggressive non boost cam.. There has been some chatting with inertia on building me a stroker motor come probably febuary and want to make sure im good on supporting mods first. If I go that route it will be getting a forged 400 stroker with a custom blower cam, and ported big valve eagle heads. Once that happens ill probably throw a smaller pulley on and go hurt some peoples feelings at the track basically going to be hoping for 600ish rwhp and need some fuel to support this and more if I decide to upgrade again in the future.
lets see some ideas and any help is greatly appreciated
