Anything in particular I should look out for? Hopefully Rampant will chime in with his experience.
Tires are on the list, but they will stay the same size, maybe an AT. Not planning on going too crazy! (As I wait for about 12 packages of stuff to show up! LMAO!)
Any other good mods to do?
Rampant has had very good luck on Amsoil 30 wt , I believe he has recently moved to a mixture of Amsoil 30 & 40 wt oil with MoS2 Molybdenum additive .
Congrats on the wings! I know that's a grueling course.
On my Ram, I've used 0W-40 SS from day one. It's quiet. As far as the motor... mine took a while to come into it's own. I (as well as many others) feel there is some sort of limiting software until you get around 5-6k miles on it. You'll feel it.
Many guys, myself included, have experienced "puffs" of smoke on startup during break-in. Mine did it probably 5 or 6 times before 5k. No discernible oil usage.
The catch can on the 6.4 is doable, but you'd have to drill into your intake and thread a fitting in because it's all internal. I wouldn't have a problem doing that if I had to pull it off for something else, but obviously you don't want to do it with the intake on the truck. I haven't really looked into it too much myself, but there is a guy over in the HD threads who is building a 6.4 right now for a project.
You're going to find that there isn't much aftermarket available for the Ram 6.4 out there. A few intakes are out now. When I did mine, K&N was the only one available but I didn't want the wet filter. I found an Amsoil dry filter and sock with the same dimensions and put that on with the rest of the K&N kit. S&B and maybe AEM have kits out now, I believe.
@RLK, the 30-40 wt mix with MOS2 is in my Yukon.
