Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
TC-W3 2 cycle oil in the gas
This is a discussion on TC-W3 2 cycle oil in the gas within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
seen this on the power wagon facebook page they discuss using 1 once of 2 cylce TC-W3 spec oil for ...
Sponsored By: Moe's Performance
Reply
Old 01-01-2017, 05:26 PM   #1 (permalink)
monteholic's Avatar
Ram Year: 2016
Engine: 6.4 hemi
Question TC-W3 2 cycle oil in the gas
they discuss using 1 once of 2 cylce TC-W3 spec oil for every 5 gallons of gas, there's over 50 pages of discussion on it at the LS forum with no negative effects, thinking about trying it on my Saturn Astra before trying it on my PW
here's the link to it at the LS forum
Been testing Oil
Sponsored Ad
Register to remove this ad.
__________________
Sam
monteholic is offline   Reply With Quote
Old 01-01-2017, 06:16 PM   #2 (permalink)
R.L.K.'s Avatar
Ram Year: 2014 4X4 QC Express 6 speed auto 355 differentials
Engine: 5.7 Hemi
Default
Yep , they use it as a UCL Upper Cylinder Lubricant.
Lots of guys do this on their 5.7L Ram's as a cleaner and metered alternative for UCL especially when running an OCC .
I suggest you posting this in the synthetic oil thread here.
https://r.tapatalk.com/shareLink?url...0&share_type=t
Synthetic Oil
Just go to the last post and post up the same thing you did above .
Hope this helps generate more discussion Sir .
R.L.K. is offline   Reply With Quote
Old 01-01-2017, 11:30 PM   #3 (permalink)
monteholic's Avatar
Ram Year: 2016
Engine: 6.4 hemi
Default
Synthetic Oil
that thread is about crankcase oil
I'm talking about using 2 stroke oil as a gasoline additive
__________________
Sam
Old 01-01-2017, 11:43 PM   #4 (permalink)
R.L.K.'s Avatar
Engine: 5.7 Hemi
Default
That thread has a thousand different subjects Sir , your TCW & many other UCL Have been discussed there extensively .
If you want discussion on UCL post it there imo .
Old 01-03-2017, 09:40 PM   #5 (permalink)
SyN's Avatar
SyN
Ram Year: 2017
Engine: 6.7L CTD
Default
640:1 ratio
I use Pennzoil Marine TC-W3!
Pennzoil 550022771 XLF Marine Synthetic Blend Engine Oil (TC-W3) - 1 Gallon https://www.amazon.com/dp/B00C43BOTM..._SkfByb80VD3NJ
Sarge & I had a few conversations. Before losing touch with him.
I will admit the only true benefit that I have actually witnessed/hearing is quieter injectors. The UCL part --->you just have to have faith/believe it is doing just that! One thing to remember the TC-W3 is totally Ashless so no deposits will be formed as well as Full of Detergents.
PM me anymore concerns or questions. I'm sure this post will be deleted here.
__________________
2017 Bighorn 2500 CC 4WD 6.7L CTD BW44~46 68RFE 3:42s w/Anti-Slip
Oil: 12Qts Chevron Delo 400LE 5W~40 & 4oz ZDDPlus w/Royal Purple Filter!
Front -68RFE/T Case- Rear: RL 75W-90 - Red Line C+ ATF - RL 75W-140/90 Mix!
Coolant: OEM for now w/RMI-25 Air Filter: OEM for Now ~ No CAI!
Fuel: (Shell) w/12oz TCW3 or 24oz Soy Shield Mileage: 137
SyN is offline   Reply With Quote
Old 01-04-2017, 04:27 AM   #6 (permalink)
Ram Year: 2016
Engine: 6.4
Default
I have dirtbikes and put the extra premix gas in my '96 Dakota so it isn't sitting around the garage. only thing you have to watch is don't put to much oil or its likely to kick on the check engine light and maybe throw some goofy codes
crazy jerry is offline   Reply With Quote
Old 01-04-2017, 10:24 AM   #7 (permalink)
SyN's Avatar
SyN
Ram Year: 2017
Engine: 6.7L CTD
Default
Jerry: @ 640:1 a CEL will never appear nor will your Kitty's show any ill effects.
Remember in normal circumstances this oil is used at either 32:1 / 40:1 / 50:1 we are talking about 640:1. Most owners have a very hard time grasping that for some reason.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
04 Must cycle key 3-4 times to start. Jason B Tech Info 0 11-09-2016 05:33 PM
Using 2 Cycle Oil in Diesel Fuel Mopar1973Man VP44 Pump 17 09-25-2016 12:24 AM
DIY Intermittent Wiper Multi Wipe per cycle RamRod37 3rd Gen DIY 4 07-24-2014 09:01 PM
Dead batteries radio cycle Speedstreetz Audio & Electronics 6 04-12-2012 05:25 PM
Motor cycle show pictures The Assassin Photos & Videos 6 02-12-2011 12:16 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
