If that's the VIS then its not even close to sealing. However it did seal quite well on the factory hood w/o dual scoops. Ill say this though with the larger cowl the vararam sounds so good.Is it supposed to seal to the hood ?? I have an aftermarket hood... Functional hood scoop and louversView attachment 90255
Which hood is that and where did you get it?If that's the VIS then its not even close to sealing. However it did seal quite well on the factory hood w/o dual scoops. Ill say this though with the larger cowl the vararam sounds so good.View attachment 209692
Its a VIS Carbon Fiber. To be honest the fitment really isn't great but it does look good. If you ever think about about purchasing let me know and I can take some more pictures and answer any questions. Just Google it and you'll find plenty of benders to purchaseWhich hood is that and where did you get it?
Why don't you just raise the rubber seal up to your hood bottom so it will seal?If that's the VIS then its not even close to sealing. However it did seal quite well on the factory hood w/o dual scoops. Ill say this though with the larger cowl the vararam sounds so good.View attachment 209692
I like how yours has that barrier around it. That would be very beneficial to me to help prevent rain water. Where did you get that lower portion from?Why don't you just raise the rubber seal up to your hood bottom so it will seal?
It's really easy, order the rubber from "Steel Rubber", clean both sides of the rubber to be mated with alcohol and bond with Super Glue. It welds the rubber together permanently.
That's how I built my seals and it works. The bond is so strong the rubber will rip before the glued area.
Not sure what lower part you're talking about, mine is a Vararam just like yours.I like how yours has that barrier around it. That would be very beneficial to me to help prevent rain water. Where did you get that lower portion from?
The snorkel is exactly what I was referring to thanks.Not sure what lower part you're talking about, mine is a Vararam just like yours.
I had to build up the rubber trim to meet the bottom of my hood with extra rubber, but if it's the orange snorkel you're referring to I made that myself.
Mines an 03 and they don't make the "Air Grabber" for my year so I had to kitbash mine to make it work.
I have 2015 ram 1500 with 87mm moes ported throttle body arh headers on way as well . Running pedal commandwe with hemi fever tune. What's best with my mods to run, an s&b or vararam ????
Made it using Styrofoam as a mold.
