ac/heat question
tim johnson
Gallatin, TN
07 Ram 1500 QC 5.7 Hemi
What would cause the temp of the drivers vents to be warmer than the temp of the passengers vents? Charged my ac yesterday and there is a very noticeable difference.
HemiBabe
DFW
Hmm... I'm not sure but I bet someone will know shortly
reefguy89
laurel de
Blend door possibly. How did you charge your ac? With one of those kits from the parts store. If so why?
tim johnson
tim johnson
Gallatin, TN
I charged my ac with a set of snap op gauges, pulled a vacuum on it for about 3 hours before hand. I swapped motors in this truck last winter and had to evacuate the system to remove the compressor. I am just now getting around to charging it again.
reefguy89
laurel de
Did you put in a new drier? Also look up the blend door problem.
http://www.heatertreater.net/index.html
Goodie1990
