Hi all, first post here...
anyway last summer I traded in my Jeep for a 2003 Ram 2500 Hemi, auto trans, electric shift t-case, and have been dealing with a problem ever since. The truck makes a horrible sounding clunk/snap, feels like right under the drivers seat, in 4wd. Only does it under load, and at less than 15 mph. If I'm light on the throttle it won't do it, the harder I am on it the more it does it. If I'm going down the road in 4wd at 20 mph or greater, it will never do it. Makes no difference whether turning or straight. I have replaced the ball joints and axle u-joint on drivers side, passenger side has no visible play, and u-joint seems to move freely. No visible play in the u-joint or double cardan joint on front drive shaft. Truck has 190k on it, it was a highway commuter, and the 4wd basically gets used in the snow only, and a couple times in the woods in summer - not off-roading, but hunting camp is a bit off the beaten path and sometimes a bit muddy. I suspect the double cardan joint in the front D-shaft, but looking for any advice or experience.
Thanks in advance.
Thanks in advance.
