Ian_Olivas
- Oct 19, 2016
- 325
- 67
- San Antonio,Tx
- 2002
- 4.7L Magnum
So first off I've been having issues with my truck lately this is the link to read whats been happening
http://www.ramforum.com/f45/engine_died_while_driving_now_will_not_start_all-92120/
But recently I sprayed starter fluid in the throttle body and the truck started up so maybe it's the fuel pump but when it started my fuse blew and when the issue happened with my truck stopping on me the fuse had blew then too. So why is it blowing is my question? Could a bad fuel pump cause it to blow or does it have to be a short somewhere? Also maybe my fuel pump is okay and the throttle position sensor is bad. what's yall opinion on this if the sensor went out? Thank you guys
UPDATE: so I swapped out the tps and it still won't start so if has to be the pump but I need to do what hootbro told me about disconnectingredients the pump and start it up again to see if the fuse blows, pray for me that when I do it does not blow and it's the pump causing this. Thanks hoot bro for the suggestion I'll do this first thing after class tomorrow
UPDATE#2: so I unplugged the fuel pump and the fuse did not blow so I think I'm finished my long stupid question of why my engine kept on dying on me. Time to replace the pump now and it's not going to be fun since I have about 15gallons in the tank
