Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > General Discussions
General Discussions
List of "whats wrong" any ideas?
This is a discussion on List of "whats wrong" any ideas? within the General Discussions forums, part of the 3rd Gen : 2002 - 2008 category!
Took my truck into to have what I thought was a leaking oil pan but it turned out to be ...
Reply
Old 03-22-2012, 02:07 AM   #1 (permalink)
MoparSickness77's Avatar
Ram Year: 2007
Default List of "whats wrong" any ideas?
Took my truck into to have what I thought was a leaking oil pan but it turned out to be timing cover gasket and seal. Then they made a list of other things wrong:
-harmonic balancer- oil soaked, worn and deteriorating damper
-drive belt tensioner assembly, slight play, will require belt
-water pump- slight play, will be required w/ timing cover gasket, recommend thermostat and gasket
-steering rack n pinion- leak
-LF upper ball joint play, recommend all
-power steering pressure line- leak
-oil pressure switch- required w/ timing cover gasket
-lower control arm bushings- worn
-steering shaft- rusting recommend R/R, clean n grease
-transfer case service- tail shaft seal leak
-slip yolk, seal and bushing worn and leaking
-transmission mount- cracking
-leaf spring bushing- worn
-LF and RF motor mounts- cracking
-radiator- slight leak at RF tank, recommend w/ timing cover gasket
-trans quick connects @ cooler- small leak
Holy crap thats alot!
Anyone done any of those things or any input? Ill be looking into doing what I can myself.
Sponsored Ad
Register to remove this ad.
MoparSickness77 is offline   Reply With Quote
Old 03-22-2012, 09:36 AM   #2 (permalink)
GhostRam94's Avatar
Ram Year: 2009 Laramie CC
Engine: 5.7 HEMI
Default
Ehh I had a similar list and about 800 and a week later it's almost completely done just need resistors for my hids(just lazy) and a new clockspring
__________________
[FONT="Comic Sans MS"][COLOR="Red"][B]-DSP 93 Tune- Moes Ported Throttle Body-Cherry Bomb Extreme- Magnaflow Y Pipe- BT Catch Can- CST 180 Tstat- Self Retro MG Heads with 35w 6k Digital Hids- 35w 6K fogs- Rampage LED Tailgate Bar- Cree reverse-LED tail bulbs- Pioneer DD- Kicker KS series Upgrade-Switchbacks- Tint-Are Tonneau- Westin Bull Bar- Kc 130watt Daylighters- 305/50/20 Nitto Terra Grapplers- - SSL 4.800 amp-12" Kicker CVR-SSl 2000watt amp- Custom Rompinram Viynls-Cobra CB and Custom PA system-Custom Bed Rug-
GhostRam94 is offline   Reply With Quote
Old 03-22-2012, 09:48 AM   #3 (permalink)
WhiteExpress's Avatar
Ram Year: 2014
Engine: 3.5 EcoBoost
Default
It looks like the shop did a very complete inspection. Do you HAVE to fix those all, No, not at all. Would it be a good move to keep your vehicle in good mechanical condition, yes.
I'm sure that if most shops did complete inspections on vehicles, they could find quite a list.
__________________
2014 F150 SuperCrew EcoBoost 4x4
WhiteExpress is offline   Reply With Quote
Old 03-22-2012, 04:07 PM   #4 (permalink)
nussdawg395's Avatar
Ram Year: 2002
Engine: 5.9 Magnum
Default
Dang! I'd juist bang em out one at a time and keep up on it. Makes sure your trucks in tip top shape and gonna last.
__________________
02 Ram 1500 SLT+ quad cab 5.9L 360 / leveled / 35 12.50 BFG all terrain ko's on 17" pro comp xtreme wheels / Led tails and 3rd brake light / sc tuned performance 91 / Efan / K&N CAI / prestige pocket fender flares
nussdawg395 is offline   Reply With Quote
Old 03-22-2012, 05:49 PM   #5 (permalink)
GhostRam94's Avatar
Engine: 5.7 HEMI
Default
X2, found thats what was vest for me one at a time
__________________
Old 03-27-2012, 06:52 PM   #6 (permalink)
Ram Year: 2007
Default
So I went into school where I go for automotive technology and I went over the list with one of my instructors and we both decided that most of the stuff listed by the shop was not critical or needing attention asap.
Did find some slight play with LF inner tie rod and I replaced both outter tie rod ends today which go rid of most of the noise I had going over bumps and whatnot.
Sad to say some shops just wanna make some extra money right away.
Reply
Tags
dodge ram service, how to fix ram, ram needs work
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
35" all terrains - better with 20", 18 or 16" wheels rambob Exterior 40 01-21-2013 12:21 PM
spotty/no accelleration and occasional "lightning bolt" on dash??? goldlifter General Discussions 10 03-14-2012 12:02 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
