NHbassman
I just bought a used 2011 Ram 1500 ST with the 4.7L engine with 66K miles on it; 1 owner, no accidents, came from upstate New York. I was taken in by the low mileage and good condition of the exterior/interior. Before I could get it to a Dodge/Ram dealership for a multi-point inspection, the starter seized-up on me a week after purchase, and then had a "no-start" issue which required attention and ended up needing a new fuel pump! Also, I have a slow leak front right tire (tire is new). There is no air volume change as I cycle the fan low-thigh, though the fan is cranking away in the dash. I brought it into the dealership for multi-point inspection after getting a new starter & fuel pump installed at a local shop, and here's what was found...
1) Rotten transmission pan
2) Rotten oil pan & screws
3) Needs new transmission cooling lines (rust)
4) Leaking left side valve cover/gasket
5) Clogged evaporator
6) Faulty dash vent valve
7) Rusted right front rim; will not make a good seal with tire
8) Struts
9) 3 open recalls
10) Leaking rear pinion
11) Leaking front pinion
....add to the list the seized starter and fuel pump I'm wondering WHAT THE HELL, RAM!!!????
Thoughts??
8) Struts
9) 3 open recalls
Thoughts??
