truckin151
Well, if you think you can do it on the ground, go out there climbe under it and just look at it for a minute. Take a look at everything that needs to be removed to get to the trans, take a look at the bolts that need to be undone up at the housing, specially the ones on top of the trans as well as all the plugs... then decide what you want to do.
