Is this a weld?
JigMig
Concerning spot on a 06 5.7 1500 with 41k miles
This too
lharrell79
Yes sir, that is a factory weld. The frames are assembled in pieces, and then welded together. Nothing to be worried about at all. A weld, if done properly, is stronger than the original material.
Here's a 2013 3500/2500 frame. Look towards the center and you will see two areas where the frame is sleeved.
TylerB
FL
Yes, that is a weld. Use a wire brush wheel to grind off the rust and paint it to protect as mush as you can. They also make a paint that neutralizes further rusting as well as protecting the surface.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
That's where they put the frame together, I've got the same on mine (just not rusted).
blackbeautyhemi
Lewistown, PA
The truck isn't actually mine. Something I'm interested in purchasing. But the car next to it was a little fiat lol.
Ah okay lol I was trying to figure out the scorpions on the wheels
Goodie1990
