usaf2006
- Mar 28, 2014
- 4,518
- 1,574
- Augusta, GA
- 2008
- Hemi 5.7
Widest rim you'll find in a 17" is 10" I think. You can't go smaller than 17s due to brake caliper clearance.
That just means you have one or the other .
There's dodge sites that you can get your build sheet , this will show you what your truck left the factory with.
Other than that , you could remove the diff cover and & count the teeth on the ring & pinion gears then divide the # of teeth from the ring gear by the # of teeth on the input pinion gear .
Example = 41 teeth on the ring ÷ 10 teeth on the pinion gear = 4.10 gear ratio .
Hope this helps !
The majority of the weight is going to be in the tire. A 38x15.5 10 ply tire is going to be a boat anchor lol. Definitely will weigh much more than your 35x12.5's, and will probably weigh at least triple what the factory wheel/tire setup was.
On that topic, my wheel tire setup is 20x9 fuel hostages with 35x12.5r20 10 ply trail grapplers. The 4 of them weigh just shy of 800lbs.
holy ****!
3.92 gears are great for 35s , alright for 37s , beyond that just know you'll loose noticable power with each up size ( weight of tire & Wheel combo) honestly you'll probably good with 38s & 17-18 " alluminum wheel.
If not it will motivate you to change your gears .
So I will be going with either a rough country or zone 5" suspension lift plus a 3" performance accessories body lift soon. And I will be leveled in the front.
I want to run 38x14.50 or 40x15.50
Can I clear these without rubbing at full turn or doing any cutting if I get wheels with a -44 offset?
If not which offset could I use to push them out far enough to clear them?
Truck is 03 qc 4x4
If ya don't have this app all ready, check it out, cuz they usually can answer all your fitment questions.
Might help ya.
Good luck!
https://www.customwheeloffset.com/
