New Light Bulbs..
jtoscano19
Mcallen, TX
I was looking into putting new light bulbs in the fog lights and headlights maybe even in the inside. I just dont know which ones to buy, I want them to be super white but not have to deal with any modifications just plug them in and thats it.
HKkid
Missouri
They are better than stock, and yes.
jtoscano19
jtoscano19
Mcallen, TX
Really HID's are plug and play??
I thought it was more complicated to get HID's in?
HKkid
Missouri
No, they make PnP kits. Talk to Jeremy.
EJM05
Somers, CT
440 Big Block
Yes. Hit up Retro shop(JJ) he is one of our vendors. He'll hook you up and give all the info.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep the Hid kits he provides are an easy install. You can pick bulb color also far as heat ranges.
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I have silverstar ZXE bulbs and they are very white. much better then the standard bulbs and much better then the other silverstar's I've bought. They provide about 4200K color. $60/pk
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
For the price they are only $20 more than the silvania zxe bulbs..... Just put mine in. They are the 35w nightvisions. (they are in my fogs)
Droid Incredible 2 on the move!!!!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Good stuff!
For HIDs, best deals around for kits that work GREAT on the Rams - check out Retro-Solutions Store. Use coupon code "JJ" and you'll save 10%!
HIDs will require a harness. No splicing, but you'll have to have a run to the battery, few grounds, rest plugs in!
professionalish
